Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: freezerfiller on February 20, 2014, 08:23:12 AM
Title: NMEA, I'm confused
Post by: freezerfiller on February 20, 2014, 08:23:12 AM
A few months ago, I wanted to get a fuel flow sensor for my boat that had a pre - NMEA 2000 engine on it.  I thought rather than buy a gauge and drill another hole in the dash,  it would be better to buy a NMEA fuel flow sensor and plug it up to the 998c SI.  I then fired it up in simulation mode and found that fuel flow/burn rate was not an option for my display outputs..  So I posted about it in the wish list section and moved on with my life, not doing anything.   Then I come across this thread:  http://forums.sideimagingsoft.com/index.php?topic=6756.msg40176#msg40176 (http://forums.sideimagingsoft.com/index.php?topic=6756.msg40176#msg40176)
So now I'm back to wondering..  If I get a NMEA backbone with a fuel flow sensor, will the unit see it and give me the option to display that if I'm not in simulation mode?
Title: Re: NMEA, I'm confused
Post by: freezerfiller on February 26, 2014, 05:06:39 PM
Don't everybody jump in at once....
Post by: newkid4si on February 26, 2014, 05:34:05 PM
I'd be glad to try to help you, but I know nothing about NMEA, so your better off without my "help".
Have you tried sending a PM to either of the guys working on the problem?  They have a lot of time and effort in it.
Post by: wpda on February 26, 2014, 06:24:51 PM
YES IT WILL WORK AS LONG AS THE INSTANCE IS RECOGNIZED AND DOES NOT CLASH AND IF THE PGN IS ALSO CORRECT
Post by: freezerfiller on February 27, 2014, 10:53:51 PM
I did send a pm to Viper.  He responded, but he has an advanced (modern) engine that has the NMEA built in.  Sounds like it may work, but I'm not in the "gamble $500 to see if it works" club.
Post by: freezerfiller on February 27, 2014, 10:54:48 PM
This sounds promising.  What is a PGN?
