Side Imaging Forums > Solix
2d transducer lost
(1/1)
Skeeter07:
Got solix units networked and was picking sonar sources. I picked for depth 1 the transducer that's connected to unit but said selected 2d transducer (Lost). After a few min. lost went away. See picture. Why would lost show when it connected to unit I was setting it up? Also why are there two gps and depth to pick? Is 2 in case number 1 fails? Thanks.
rnvinc:
Networking is designed to "look for" the next best source if the selected source is lost for any reason ...
A source "Lost" indicates a bad connection or a failing device ...
You might disconnect and reconnect the xducer connector to see if there may be a bad connection ...
TroyBoy30:
it will also show lost on a transducer that has pinging turned off. there are 2 options for a main and a backup. some options have as many as 4 options
Navigation
[0] Message Index
Go to full version
