Other Humminbird Products > Matrix Series Fishing Systems
Need help with Matrix97: GPS and update problems
kkt_mag:
Sorry for the previous, garbled response (poor choice to try to respond using my iphone). I have since made corrections in that previously garbled response.
Bob B:
If you could find someone else close to test your unit with their GPS, that would be an cheap way to find out if your unit is toast.....It still bothers me that your unit is showing low voltage. I suspect a problem in the unit.
If budget is a concern, you could watch some of the used forums and pick up a nice unit for less money and maybe even expand your horizons in a SI unit.....PM me if you are interested in links to a couple used forums.
rnvinc:
A call to HB will help determine the proper procedure for updating your Matrix ...
1-800-633-1468
And they may also be able to offer advice on the voltage issue Bob is mentioning ...
Bob B:
I just had another thought ...... if you connect nothing to the unit but power, do you still have the low voltage reading on the unit.....It is possible the GPS antenna itself is somehow dragging down the power in the unit.
Navigation
[0] Message Index
[*] Previous page
Go to full version
