Side Imaging Forums > 798c SI
798C SI and 788CI Navionics
(1/1)
craftjl60:
I have a 798C SI at my console and a 788CI at my trolling motor, do I need to buy two NAV + SonarChart SD cards from Navionics for each one of my fish finders OR can you buy one SD card and load NAV+ SonarChart on both fish finders????
fshndude:
That's interesting, as I had the same set up. I just used two cards, then I up graded to a 899 on the bow and used a auto chart pro. The up grade to the auto chart pro is unbelievable. I still use the Navionics in the console. I was less than pleased with even the high end card from them. You go out and record them send it to them. To answer you question I am sorry I never tried that.
October1:
--- Quote from: fshndude on February 23, 2017, 12:05:33 PM ---That's interesting, as I had the same set up. I just used two cards, then I up graded to a 899 on the bow and used a auto chart pro. The up grade to the auto chart pro is unbelievable. I still use the Navionics in the console. I was less than pleased with even the high end card from them. You go out and record them send it to them. To answer you question I am sorry I never tried that.
--- End quote ---
fshndude, what makes auto chart pro unbelievable?
craftjl60:
I finished chatting with Navionics. They said I could move the SD card from one unit to the other as needed. That would be a pain, therefore I would need two SD cards. Because the units came with "Navionics Charts Inside", there are no updates or discounts for the units. Exp. the "Get 50.00 Back". O, Well.
rnvinc:
There were a few select models of a few units that came bundled with a Navionics card ...
That specific Navionics card (from the bundle deal) can only be used in a unit that was also in the select few in the bundle deal ...
Navigation
[0] Message Index
Go to full version
