Other Humminbird Products > Matrix Series Fishing Systems
Matrix 97 Software Update
<< < (4/5) > >>
Maxposeidon:
Greg, here again the old antena to the gPS with red, white , black and green cable and the other one shows the pigtail with 3 cables NO RED ONE
Max
Humminbird_Greg:
Max,
If the wire colors on the older GPS Receiver are Black, Green and White than it was not the original GPS that we shipped with the Matrix 97 units and will make troubleshooting more difficult.  What I was trying to get you to do is confirm that there was voltage going to the GPS Receiver which can be done by checking for 12 volts between the Red and Black pigtail wires.  The newer GPS Receiver cables do not have the Red wire, so it cannot be checked there.  However, if you have already cut the main GPS Cable (the one that runs from the connector to the actual GPS Receiver) you can still check between the Red and Black wires of that cable for the 12 volts.  Otherwise there is nothing else you can check or test as you said there are no other Humminbirds in the area.
Humminbird_Greg:
--- Quote from: Maxposeidon on May 22, 2014, 04:00:50 PM ---Greg, here again the old antena to the gPS with red, white , black and green cable and the other one shows the pigtail with 3 cables NO RED ONE
Max
--- End quote ---
Guess I was trying to post at the same time you were Max.
Connect up the old GPS Receiver and test between the Red and Black wires in the main cable (not the pigtail) for 12 volts.  I’m actually hoping that it is not there.
Maxposeidon:
Greg checking the red and black cable it shows 3- 4 V
Max
Maxposeidon:
It shows around 4 V Greg red and black in the main cable
MAx
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
