Software and Software Development > HBSI Tools and Converter
ERROR: Incorrect checkbit35: at position 35
promapper:
Every file I try to convert with the HBSI Converter returns this error.
ERROR: Incorrect checkbit35: at position 35Has anyone else seen this.
Running a 998 and 6.610 software
Windows 7
other converters will work but will not generate the proper format for Yellowfin
RGecy:
I will have this fixed this weekend.
Robert.
promapper:
you are super! Thanks for looking into it!
JoeH:
I have downloaded what I believe is the latest version of HBSI (1.1.0.1, Copyright 2013) and I am getting this message. My unit is a 798CI HD SI COMBO.
The converted .872 file has 0 bytes.. Thanks for any insights.
surveyor:
Dear RGacy,
Can you PLEASE check why this Error code below keeps popping up in HBSI Convertor?
ERROR: Incorrect CheckBit 35 at Position: 35
I run a Win7 64 Bit window version and a 1197 and 1198 data with older recorded files (old Firmware) and newest Firmware updates.
None helps.
When I run V 1.1.0.1. on a standard Win7 32 Bits 10.1 Inch laptop, it runs fine???
Can you help me or can I work arround that?
I already tried compatibillity with other Window Versions, yet none helps.
Kindest regards and thank you for your reply in advance,
Surveyor
Navigation
[0] Message Index
[#] Next page
Go to full version
