Side Imaging Forums > 997c SI, 998c SI & 999ci HD SI
999ci - Is transducer going bad or something else
(1/1)
FL_freshwater:
The last two times I have taken the boat out the down and side imaging just looks horrible. Even the normal sonar is useless. I have the latest updates installed. I watched tutorial videos and have tried every setting I can with no luck. Even when I tried to use the simulator it didn't look as bad as the attached pics but it didn't look as good as it once did a few months ago. The attached pics are with the transducer setting in a bucket of water at the house. The good pic is what it used to look like. Any thoughts or suggestions on what I should check?
FL_freshwater:
More pics, messed up on the first post
rnvinc:
Have you tried Restore Defaults ... ??
FL_freshwater:
I did try that. Those pics are after restoring and verifying I had latest software updates
rnvinc:
--- Quote from: FL_freshwater on February 14, 2022, 06:44:27 AM ---I did try that. Those pics are after restoring and verifying I had latest software updates
--- End quote ---
The next troubleshooting step would be to try your head unit on another xducer - or another xducer on your head unit ...
Navigation
[0] Message Index
Go to full version
