General => General Discussion => Topic started by: T.G on June 17, 2011, 02:53:14 AM
Title: distance between 2 way points
Post by: T.G on June 17, 2011, 02:53:14 AM
hello i was wondering if there is a way on my 898si to measure the distance between 2 way points, with out my boat being one of them? would it be in the create a route section ? i had a look but could not figure it out
thanks T.G
Title: Re: distance between 2 way points
Post by: Humminbird_Greg on June 17, 2011, 08:32:09 AM
No there is not.
Post by: sonar2000 on June 17, 2011, 04:25:23 PM
HMMMM Maybe Humminbird should have bought lowrance instead of Navico....
Greg, are we falling behind?????
Post by: T.G on June 17, 2011, 09:40:14 PM
ok thanks for the reply, the reason i ask is ,while out in my boat yesterday i had to tow a fellow home who had broken down,while doing this i set my unit to record & slowly headed back to his ramp,on the way we passed some artificial reefs that have been put into our lake,now as i got close to some of these reefs i noticed that these reefs were slightly away from the marks that i have inserted,that were provided from our fisheries website here in aus.I zoomed right in & they were still off the mark, would using map offset correct this,bearing in mind i do not have a navionics card ,just the standard base map & having watched the how to map off set video, it explains to use a structure like a bridge to go off, this system does not have anything like that.
thanks T.G
Post by: stillbear on June 18, 2011, 06:20:07 AM
T.G Read this.       http://forums.sideimagingsoft.com/index.php?topic=52.msg99#msg99 (http://forums.sideimagingsoft.com/index.php?topic=52.msg99#msg99)
http://forums.sideimagingsoft.com/index.php?topic=462.0 (http://forums.sideimagingsoft.com/index.php?topic=462.0)
        GARY
Post by: T.G on June 23, 2011, 05:44:37 AM
Hi thanks for the links Gary,they told me just what I needed to know, I will try to use the search function better next time.
T.G
Post by: stillbear on June 23, 2011, 07:15:26 PM
I am glad you got it. Gary
