Other Interest => DIY - Side Scan Sonar and towfish => Topic started by: Kenneth W. Sørensen on February 09, 2016, 02:08:02 PM
Title: Broken transducer cable (gland)
Post by: Kenneth W. Sørensen on February 09, 2016, 02:08:02 PM
Hi
I just finish my tow fish, unfortunately have a small problem on my transducer.
My transducer cable is damage just above the transducer itself. The cable gland was also damage so I had to remove it.
I am not worried about the cable, as I sure I able to solder it together. My biggest concern is how to seal the transducer so it would not flood the first time I put it back in the water.
Any suggestions on how to approach this?
[attach=3]
[attach=4]
[attach=5]
Title: Re: Broken transducer cable (gland)
Post by: Rüdiger on February 10, 2016, 04:32:20 AM
Hi Kenneth
All make good clean, abrade with fine sandpaper and then sealed with a sealant (Sikaflex, Bilthema ect). Here, the sealant generously apply and a cone around the cable forms.
mvh
Rüdiger
Post by: Kenneth W. Sørensen on March 08, 2016, 02:45:14 PM
Hi Rüger
Thanks for the reply.
Unfortunately the ground wire was damage and broken off just above the transducer. I manage to grind a hole in the transducer and solder the ground wire back on.
Now to the big question. Is it possible to measure the transducer circuit?
[attach=1]
Post by: Rüdiger on March 19, 2016, 04:49:54 AM
Hi Kenneth
For possible measured values of ask best "Rickard".
mvh
Rüdiger
Post by: Rickard on March 19, 2016, 05:16:42 PM
I heard you...
I don't think measuring the circiuts is needed. A damage to the cable should have no effect on the interior of the transducer. Just follow the colors of the wires and reconnect them.
