Other Humminbird Products > Lakemaster AutoChart
autocharts import kml
(1/1)
D S:
i have a kml of my local shoreline i want to import as the zerolines shoreline is not that accurate and cuts off some of my data
but i am unable to import kml to autocharts......... it says no data found...
i checked in google earth and it diplays fine... any suggestions?
I will post pics of cut off data from autocharts later today
PS the list of lakes is incredible (ie) in Saskatchewan Canada i am able to find every lake i have fished even tiny trout lakes from hanson lake road
any help would be appreciated
ds
CamoHunter:
I had to add a couple of islands that did not show in Autochart. I created a separate Google Earth path for each island. I then save each path as a .kml file. Autochart had no problem importing the saved .kml files.
Not sure why you're having an issue.
Pickeral:
Hey Dave
Does Auto Charts have Rafferty Reservoir. Its between Weyburn and Estevan.
D S:
well i re-did kml on google earth and it worked?? operator error......:(
most zerolines are acceptable but I wanted detail (+++) for my home water body...
and yes raferty resevoir is on zerolines will attach images
DS
Navigation
[0] Message Index
Go to full version
