General > General Discussion
Where to save data? zero line card or ScanDisk card
(1/1)
GM:
After a while reading several posts I am still confused about where to save data obtained during acquisition (AutoChart live with Solix, helix, apex, etc). So, I must buy Zero line cards for this or can I simply use regular card disks such as those ScanDisk ones. Also, I read that files saved to zero line cards are only in ACU format and those saved to other cards (eg. ScanDisk) are in SON/DAT format, is it right? Any hint is appreciated.
Best,
GM
GM:
Sorry for bumping this one, I would appreciate your suggestions about this, thanks in advance.
rnvinc:
You might also post you AutoChart questions in the AutoChart forum ... some guys may not see it here in the General forum ...
http://forums.sideimagingsoft.com/index.php?board=76.0
Here is some additional info :
http://forums.sideimagingsoft.com/index.php?topic=8122.0
Humminbird may also be able to help ...
1-800-633-1468
GM:
Thanks for the quick reply! I will post it there.
rnvinc:
All the AutoChart products must be used with the Zero Line card ...
A regular SD Card is for Nav data, ScreenShots, or recording Sonar ...
A recording on a regular SD Card can be imported into the AutoChart PC program to create custom maps ... but must then be exported to a Zero Line card to be used in the HB unit as a map card ...
Navigation
[0] Message Index
Go to full version
