Side Imaging Forums > 997c SI, 998c SI & 999ci HD SI
Connecting AIS to Marine Band Radio (uniden UM415) to 998
(1/1)
6speedy3:
What is the procedure to connect my marine radio, I have the user manuals for both and it seems pretty straight forward. However, can I get the necessary AIS connector cable from Humminbird and if not where?
6speedy3:
I can connect directly to the receiver and not connect to the control head so I won't need anything but some wire and some solder seal marine butt connectors.
rnvinc:
HB may be able to help if no one pops in to answer your question ...
1-800-633-1468
6speedy3:
By the way I had to replace the original GPS receiver with the AS GRP receiver the Baud rate on the Uniden UM415 is 4800.
6speedy3:
It works,easy peasy!White wire on AS GRP Precision receiver to green on UM415 Uniden and black ground on receiver to bare ground on Uniden and I'm good to go!
Navigation
[0] Message Index
Go to full version
