Other Humminbird Products => Lakemaster AutoChart => Topic started by: D S on June 08, 2016, 12:08:57 AM
has anyone noticed that when u try to switch from say AC background to AC1 or IMG that the unit will reboot ?
tried this on base layer setting and overlay setting
any ideas out there
DS
I try to switch from AC background to AC1 and AC2 no problem. I test that on Helix12 an Onix10.
Only time that's happened to me, is when I copy the AC folder from a different card to one. The AutoChart Pro maps only work on the card they were created on.
Not saying that is your issue, but you may have to delete the AC folders, and recreate your map.
camo
I had to rename my AC file as I ran the minnesota demo map and live in Saskatchewan,
so to fix my card I have created an AC and AC1 on the card
otherwise I get the error that says ( map will not fit)
is there another way around that issue?
ds
