Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: hoselrocket on January 09, 2010, 02:40:20 PM
I have downloaded the Hummingbird PC software. I load the sd card into my laptop and try to download my waypoints to the program. The sd card is read by the computer and no waypoints show up on the HB PC program. I know that the sd card had my waypoints on it, i can view the screen snapshots with a normal photo program. Does anyone have any advice for me
Did you save and export ALL your Nav.-Data before you removed the card from the unit Rocket?
Regards / Harry
No I did not. Do i reconnect the unit and then export the dat to the sd card? Where do i find the prompt to export the data?
Thanks for the help
If you haven't deleted the Nav Data from your unit they are still there. Just reconnect, power up, go into the Nav.- menu and scroll down. Save the current track, scroll down further, export all Nav.- Data and you should be good.
Hope that helps.
Good luck / Harry
Where can the program be downloaded from?
You can download Humminbird PC from the Humminbird website or you can also find it here in the download section.
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=11 (http://forums.sideimagingsoft.com/index.php?action=downloads;cat=11)
Good Luck,
