Other Humminbird Products => Accessories => Topic started by: Skunkedagain on March 12, 2013, 12:08:17 AM
In the istallation instructions, it states, "using a level, locate a flat surface to mount". Is it really necessary that this thing is mounted horizontal and level? Thanks
Dont think need to be mount horizontal...
Just have finish to install mine and is vertical
Nope, it shouldn't matter which direction it is mounted.
Thanks! That makes things alot easier for me!
If you read that again it will say to use a level to find a FLAT SURFACE. It doesn't have to be level. They just dont want a surface that is crowned in the middle so when you snug it down you down break it. Hope that helps.
Thanks. That makes sense now. I'm getting ready to mount mine.
Bless you.
