Other Humminbird Products => Lakemaster AutoChart => Topic started by: RonnieB on April 27, 2016, 04:43:29 PM
Is there a way to turn off some or all of the icons on Lakemaster Plus? When I am trying to see a full view of lake the icons cover everything up. Not too much of a problem when I zoom real close.
Also, what are the icons? I thought I read where you could cursor over icon, click and get info as Navionics does it.
You should be able to cursor to the icon and then press the checkmark button for info ...
You may be able to turn some of that off under the Chart tab and down to "Chart Detail" = set to "Custom" ...which will add another "Menu" selection directly under the "Chart Detail" "Menu" ...
Then enter the Custom Detail "Menu" for selections to turn off ...
On my Onix, and LM+ SE States I do not have Chart Detail and icons do not open up when clicked on. May just be MS lakes?
My mistake Ronnie ... My info of the Chart Detail "Menu" was for core units ...
I see now in your sig you have ONIX ...
I will have to experiment on my ONIX and see if I can find some options for turning anything off on the map card ...
Thanks Rickie, I sent HB CS an email asking them also. Some Lakes there are not many Icons to worry about.
This may just be wishful thinking, but is there a way change at what zoom level the the depth numbers appear? Sometimes I like zooming out and looking at a larger map area. I hate to have to cursor over an area and zoom in to see depth numbers, then zoom out find another area then zoom in again to see depth. For a remedy, I fine tune color/depth/range to what I am looking for. (actually pretty neat).
I'm not sure Ronnie ... I'll have to do some experimenting on my ONIX to see if I can find something for you ...
Humminbird reply:
"Thank you for contacting Humminbird. We appreciate your interest in our products. The feature turning icons on/off can be done with the Navionics card not Lake Master unless you are zoomed in close. In the Onix unit under your favorites you can click on the icon."
Yes or No??? I knew that on Nav & LM you have to zoom into see some of the Icons. But I do not know about the favorites??? I won't be able to look at my Onix for 2 wks.
