Side Imaging Forums => 898c SI => Topic started by: maachuu on July 03, 2013, 10:17:28 PM
transducer to my 898 is the AS-SI-DB-Y. Will be connecting the SI ducer that came with the 898 and a XNT-9-20-T, so that I can mount the XNT-9-20-T lower on the transom to try and get depth reading while on plane at speed. Just wanted to make sure before I ordered
thanks
maachuu
after more research and reading, I have ordered the AS-SI-DB-Y cable, it is what I need to do the job I do believe :)
Here is good info on installing the shoot thru hull xducer...
Be sure and test the install spot before epoxying...
http://www.bbcboards.net/humminbird-sonar-gps/172972-installation-networking-information-resource.html#post1538600 (http://www.bbcboards.net/humminbird-sonar-gps/172972-installation-networking-information-resource.html#post1538600)
