General => General Discussion => Topic started by: Gregpen on November 15, 2012, 05:46:52 PM
Hi Guys,
So I've fitted a 798c SI to my console on a RAM mount and have used the standard SI transducer on the transom, I have added a TS 3 switch and a XTM 9 HDSI 180 T to the trolling motor. Do i need to change any thing in the Transducer Select Menu or is it simply switch through the TS3.
Cheers
Just use the TS3 switch Gregpen. There is no menu selection in the 798c Si units for the HDSi transducer. It uses the same “Compact SideScan” menu setting that the CSi transducer does.
Thanks Greg for the response.
