Side Imaging Forums => 1197c SI, 1198c SI & 1199ci HD SI => Topic started by: grizwilson on December 31, 2023, 12:04:44 PM
First, I am a bit slow so please be patient. My interlink is "flaking out" so I removed my 798 and interlink from the loop. Purchased a ethernet cable to connect 998 and 1197. In the shed so far, seem to recognize each other. So what will I need to do to have them share waypoints? That is the main need, as I often mark spots at the bow, then later use the helm to travel back to them. Will just happen like it did on interlink or ????? Thanks
g
Hey Les ... I’m here too ...
As mentioned at the other forum - look under the Accessories tab for “Share Waypoints” ...
will give it a go when it warms up in a day or two if I am up to it. THANK YOU.
Hey Rickie sent an PM, maybe someone else can chime in... When I took the interlink out it had a choke or filter ahead of each unit where the GPS went in, should I dump those as now the each unit will have its own puck going directly to each unit? Thanks
It certainly would not hurt leaving in ...
