Side Imaging Forums => Solix => Topic started by: bassmasterG13 on December 14, 2018, 06:04:25 PM
I recently purchased a 2014 skeeter 190tzx. I will be adding a ultrex and am planning on adding a unit at the bow as well as console. The boat has the stock 789 unit in console. Will I be able to hook the thru Hull transducer currently mounted in the boat to any new unit for high speed readings ? Also Is there a major difference in the solix 12 chirp mega sI gpsi (model 410400-1) and the brand new gen2 si solix? I am looking to mount the solix 12 at the console and maybe a helix at the bow. Any thoughts or recommendations would be greatly appreciated. Thanks !
Please verify which unit model you have - there was no 789 ...
Also verify which xducer is epoxied in the bilge - there should be a model number printed on the cable about 1ft from the connector end ...
I haven't heard if dealers have even received the SOLIX G2 units yet ...
