Side Imaging Forums > 987c SI and 981c SI
GPS receiver
Humminbird_Greg:
That’s a hard call. If it weren’t for the corrosion on the pins of the GR16 I would go with it no question. With the corrosion though it’s a hard call to make. You would need to be able to clean the corrosion off without damaging the pins and hope that there is enough material left for the pins to make good contact in the 981 unit. For me I would go with the GR16 anyways but then I could get a used GPS Receiver cable and splice on a different connector if needed.
Navigation
[0] Message Index
[*] Previous page
Go to full version
