Software and Software Development > Other 3rd Party Software
Searching a Software: One COM Port to n virtual Com Ports
pebe:
I am searching for a com port multiplier ;D
Means:
a Programm which listen to the com Port where the NMEA Data is comming to the PC
and then offers for example 2 virtual com ports and output the NMEA.
So i can use two software Programms, each connect to one virtual com port.
So both Programms can be used at the same time Live.
Anyone knows such a Programm ?
pebe
RGecy:
There are certainly virtual COM port drivers, here is a Google Search for Virtual COM port.
Here is one I found: http://www.ftdichip.com/Drivers/VCP.htm
Good Luck,
Chiboo:
This software named as GPSGate.
"Using Franson GpsGate it is possible to share one GPS between many
applications running on a laptop or handheld computer. Today’s
solutions only allow one application to take exclusive access of a
connected GPS. As more applications are becoming position aware,
GPS sharing will become a necessity. "
pebe:
Thank you all.
Cant believe that there are so many Solutions available.
I mentioned that this was a unpopular thing... but i am wrong ;D
Now i will look at the search results from google, if there are Opensource or even free Programms available.
I also got an idea:
Because ther is no handshake needed, i will just contact two serial ports together, GRND and Transmit from the Unit to
each GND and RCV of the two serial ports.
This should work i think, because i dont have to deal with handshake signals (RTS/CTS and so on.)
radudragusi:
If the solution is not working I'll build a small box for you.
Navigation
[0] Message Index
[#] Next page
Go to full version
