General => General Discussion => Topic started by: captscoob38 on November 13, 2012, 04:13:28 AM
Is there anything special you have to do to get 1kw out of your unit?? I have the Airmar TM260 1kw transducer and select the dual 50/100 in the menu?
Selecting the “Dual 50/200” menu setting in the “Transducer Select” menu (also called “Connected Transducer” menu in some units/software versions) and using the appropriate transducer is all you have to do.
