Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: larry e frazier on August 30, 2010, 02:48:19 AM
I can not change my screen data on this one screen . I selected the screen before I changed the data to what I wanted. How do you edit this screen that I have saved . The unit is a 998
Which view can you not change the data?
The view is 2d sonar& Navionics map, The data I want to change is the bearing to surface temp. I went in and changed the data and it changed every screen but the one saved on quick view. Am I doing something wrong?
No you are not. Some of the digital readouts are locked on some of the Views. Try setting one of the other readouts to surface temp instead.
