Side Imaging Forums => 898c SI => Topic started by: TazzMan on March 02, 2011, 06:41:46 AM
I have tried to to use the map offset. I know there is a way to set the depth offset. If the lake water is lower or higher than when the map was made then the depth lines on the map are not correct. I set my unit to highlight 20ft and the water is only 16ft. I have a navonics card for my area. I set the offset like it says but noght seems to change and the depth lines same the same. maybe I am doing something wrong. please advise!!!
Tazzman,
I think that is only available for the Lakemaster Charts.
http://forums.sideimagingsoft.com/index.php?topic=1190.0 (http://forums.sideimagingsoft.com/index.php?topic=1190.0)
Tazzman I think you are talking about shaded depth that is what Navionics at this time has.
Lake Master has water offset it is exclusively made for HB. I use both.
