Side Imaging Forums > Helix Series Units
Helix 9 SI GPS missing Autochart Live?
braunjo:
I bought a Helix 9 SI GPS back in 2016 and have tried a few times to get Autochart Live to work but have not had any luck. I finally had time this last weekend to dive into it more and noticed that in the menus, all references are just "AutoChart" and not "AutoChart Live"....every video and picture that I have found of the menu's online include Live.
Am I missing something, or does my Helix (which says Autochart Live on the box) not actually have Live? As I understand it, Live is standard on all 9 SI GPS models.
I have tried many many times to turn on AutoChart in the menu's and have gone through all the settings multiple times, but nothing ever shows up on the map and the top right corner always says "No Chart".
I do not have a Zero Lines card yet, but was going to test it out with the 8 hours included recording before I buy the card.
Has anyone else run into this issue?
rnvinc:
Have you adjusted the Transparency setting in the AutoChart Live Menu ...??
braunjo:
I have tried both ends of the transparency bar as well as the middle and all give the same result.
rnvinc:
Try Restore Defaults under the Setup tab ...
If that doesn't work - call HB ...
1-800-633-1468
Sawyer:
I agree with Rickie if you have a Helix 9 G2?
Navigation
[0] Message Index
[#] Next page
Go to full version
