Side Imaging Forums => 1197c SI, 1198c SI & 1199ci HD SI => Topic started by: goodwinexplorer on August 02, 2012, 05:57:33 AM
hi i upgraded to the latest software on my 1197 csi unit after about 1 hour the gps stops working, if i turn the unit off and on, it resets fine, then 1 hour later the same problem.
i am recording the side scan to sd card at the time on a 15 mb/s ultra scandisk if i put a higher speed card 95 mb/s the system stops a 30mb/s the system jerks.
i did not have this problem last season is it the upgrade?
If you are not recording does it work ok?
We use a 2mb and record for 30 minutes and it is ok.
We are at the current software level..
i have not tried, i used a 2gb card and a 4 gb stop start the recordings every 20 minutes which i have been doing for 4 years and not had a problem.
I mistyped. we are using the 2gb cards. Without a problem.
Our code is the 6.3
Are you using waypoints on a card?
Darn, I cant type today..
We are on release 6.310
I must need a pint of lagar and lime..
no i am using 6.180 i try the 6.3 and i am not using way points only recording the ss, i am using the gps to run a plotter via serial to usb converter as well
Try updating the unit 6.180 messed up a lot of units. The newest update fixed a lot of 6.180 problems.
Roddy
I know I sound like a broken record, but I must say again:
Fully charge and load test your battery.
According to your post, your battery is a year older from last season.
Intermittant problems are often associated with the power supply.
12.8 is the reading on the unit the units dose not switch off just the gps stops working, going to try the new soft ware at the week end
12.8 only means your battery has adequate voltage.
It doesn't mean it can carry a load for any length of time.
Your voltage may be dipping down too low to run all of your
accessories, but still be enough to keep the unit on.
Also, check your power connections.
A small bump every once in a while could cause a lapse
in power.
