Side Imaging Forums => 898c SI => Topic started by: Rocktober on June 16, 2012, 11:05:14 PM
I am new to this forum and this is my first post. I just recieved my 898 today and when I took the head/control unit out of the box I noticed a rattling noise. It sounds like there is a loose screw in there somewhere. Should I be concerned? Thanks in advance for any advice.
Welcome! Returne the unit for a new one. Roddy
Nothing shold be inside the head that will rattle. Return it at once for a new unit..
Rocktober,
Make sure that it is not the bail wire that goes to the map/memory card door. Otherwise there should be no rattling from the unit. If there is; call the Humminbird Customer Resource folks about this.
Greg,
Thank you for your response. The wire you mentioned was the first thing I checked. I have already shipped the rattling 898 back (at my expense) and ordered another one from a different seller. Hopefully I have better luck the next time around. I will be leaving this weekend to go to Kentucky Lake and was really needing to have the graph installed by this Friday, but now who knows. I am a little frustrated right now.
