Side Imaging Forums > 898c SI
networking 898 to helix g2n
(1/1)
Ranger175vs:
I have a 898 hd si, can it network to helix g2n and share and display sonar data ? the 898 uses original transducer shipped with unit
I want to only network thses two units and have no plans to use ilink
fshndude:
I am doing the same thing. I have bought a 5' cable to route my Helix 9G2N to the Ethernet box, its a AS EC SE 5 #720073-6 I do believe. Then I have two AS EC QDE 700 #720074-1. Plus the 5 port box #408450-1. I will be also connecting a Ulterra. The Ulterra came with a very long cable that I am using to connect the console 899 HD to the Ethernet box. I also plan on getting a Helix 7 with no transducer for the T/M as it came with a DI transducer built in. It will be networked into the system. I hope this helps you out, as I am learning about all of this. With the weather I have had my T/M on the boat for two weeks but not able to get out to get it all set up. You will find very good manuals on the HB web site.
rnvinc:
You can share Waypoints, accessories, and limited Sonar technologies ...
Here is the ethernet Chart ...
https://www.humminbird.com/sites/humminbird_site/files/transducer_support_grid_v10_0.pdf
CHIRP must be shut off the G2N to share any Sonar to core numbered series ...
Ranger175vs:
yes this looks like it will it will do what I want thanks for the part info I am looking to upgrade from my original 570 di
agian thanks fot the info
Navigation
[0] Message Index
Go to full version
