Side Imaging Forums => 798c SI => Topic started by: BaitCaster on April 15, 2011, 10:08:04 AM
Title: Rooster Tail
Post by: BaitCaster on April 15, 2011, 10:08:04 AM
So, took the boat out for the first outing since installing the fish finder.  My transducer throws a pretty bog rooster tail at WOT.  Is this normal/expected?  Anything I should do about it?
Title: Re: Rooster Tail
Post by: jjbch on April 15, 2011, 10:36:06 PM
I'm new to this as well, but I have read numerous posts about a plug that is suppose to eliminate that.  There are also post from people that have used other methods to solve that problem.  I think that Hummingbird has the plug.   There is a wealth of information on this site and quite a few guys that really know their stuff.
Post by: BaitCaster on April 17, 2011, 12:23:41 PM
Thanks for that.  I found the plug and installed it.  We'll see how it works.
Post by: Curt - RI on April 28, 2011, 08:08:57 PM
Can you explain what kind of plug you're referring to? Typically, a rooster tail is the result of a transducer being too low in the water when the boat is on plane. Or that's the way I've always understood it anyway.
Post by: FuzzyGrub on April 28, 2011, 10:38:16 PM
It goes between the arms on the mount.  From your earlier pictures, it looks like yours is installed.
Post by: BaitCaster on April 29, 2011, 10:01:34 AM
This is what the pug looks like.  I installed it on my transducer (luckily I didn't throw it out thinking it was just a spare part).  Taking the boat out tomorrow and will see how it works.
[attachment=1]
Post by: BaitCaster on May 02, 2011, 11:08:36 AM
Problem solved.  The plug completely eliminated the rooster tail.
Post by: clsmith1 on May 20, 2011, 02:23:21 PM
How does this plug keep you from  spraying  a rooster tail  when  your transducer is mounted  below  the bottom of the boat?  whre is the best place to mount the transducer on a alum.  boat?
Post by: edwardpic on May 20, 2011, 03:19:46 PM
where did you get the plug? directly from HB?
Post by: Roddy on May 20, 2011, 05:21:58 PM
Edward: The plug stops the water from passing between the xducer wire and the mount. It plugs the space. Roddy
Post by: Roddy on May 21, 2011, 12:04:36 AM
Edward; If the plug was not part of the kit call Humminbird to order the part. it just snaps in.  :) Roddy
Post by: Phiznat5000 on June 22, 2011, 02:25:43 PM
LOL! Hey man I made the SAME mistake! I forgot to install the plug as well. Full speed in my boat and it was shooting water probably a good 15ft in the air. Its always the little things.
