Side Imaging Forums => 898c SI => Topic started by: snowman48047 on July 30, 2018, 08:15:10 AM
Title: 899ci HD Si - power issue and solution
Post by: snowman48047 on July 30, 2018, 08:15:10 AM
Turning unit on, the h'bird logo shows for 1 second then the unit shuts off.   I can use spare power cord on separate battery and unit powers up fine and runs simulator mode. I'm thinking either low voltage or bad power/ground connection. Any other things to check? Everything worked fine 3 weeks ago.
Title: Re: 899ci HD Si
Post by: rnvinc on July 30, 2018, 10:09:48 PM
Easiest test is to have the battery load tested (free at most auto parts stores)  ...
Then delve into wiring if the battery checks good  ...
Title: Re: 899ci HD Si - power issue and solution
Post by: snowman48047 on August 06, 2018, 10:07:35 AM
battery checked out good - found a splice corroded so bad it fell apart when I unwrapped the tape.
Post by: newkid4si on August 06, 2018, 04:22:02 PM
Thank you for sharing the solution to your problem.   Sometimes, after Rickie suggest trouble shooting ideas, we don't hear back on the out come.   Although, if I were to bet, I'd borrow money to bet he is correct.
