Side Imaging Forums => 898c SI => Topic started by: Turk on March 07, 2013, 11:25:55 AM
I have an 898si combo with the transducer mounted at the rear of my boat and was thinking on adding a tolling motor transducer. On the Humminbird website it give me the model number for the side imaging transducer but not one for 2D sonar only. Is there a 2D only transducer for this model and is there any thing else I need to complete the job (switches,extra cables). I did a search of the site but couldn't find the answer. Thanks for the help.
Turk
Turk,
All you need is the trolling motor HDSi transducer and a TS3 Transducer Switch. The HDSi transducer has the 2D sonar built into it.
So you are saying Humminbird doesn't offer a 2D only transducer for the 898. I mostly use the 2D when I'm working the trolling motor and would like to see whats under my feet not the back of the boat and I figured why spend the money on the Si transducer if i can get a 2D transducer and save a couple bucks.
Yes we do make a 2D only transducer that will work with the 898c Si units. Look for the XTM-9-20-T transducer. When you toggle the switch you will also need to change the Transducer Selected (or could be called Connected Transducer) menu to whichever transducer the unit is connected to.
Thanks! Now I need the Ice to Melt.
